bornes mobiles
+12
el51
cadaguy
Morinio
Davide R
alain68
Frankois
Clio_IV
Marsu Pilami
16 participants
Re: bornes mobiles
Traduction de la 1ère ligne :
1 2 3 4 5 6 7 8 9 10
navidad- Messages : 66
Re: bornes mobiles
Because I live in NorthWest of Italy, so I can understand French because it's similar to our dialect, but I cannot write in French. I can write in Italian if you preferBonjour, pour quelles raisons écrivez vous en Anglais
https://www.youtube.com/watch?v=rxUm-2x-2dM
Re: bornes mobiles
Davide R a écrit:Very nice product. The only problem is that home plug is not certified for 16A continuous use, so you could burn your home inlet.
I'm designing a similar one, but:
- up to 32A (7.7kW, full Zoe charge in <3h)
- a bit cheaper (<600€)
The main advantage of mode-3 (wall-box) is that they could communicate with the electrical grid, to dynamically optimize energy draw.
The main advantage of mode-2 (charging cable) is that you can use them anywhere, plugging them in any inlet.
Current available wall-boxes lack both of them.
Another advantage of wall boxes is the greater power available. But if you have only 1-phase available, with 32A charging cable there is no more difference.
So it can replace the wall box, you need only to install a very cheap (<50€) industrial 32A plug in your garage for 3h full charge, and using small, current-limiting plug adapters you can connect to any inlet you can find anywhere (max current is limited by kind of plug)
Bonjour David
Pense tu que les wallbox actuelles peuvent être intégrées dans un smartgrid ?
nh2o2- Messages : 1863
Re: bornes mobiles
Public ones are in outside public places (mainly fuel stations and public parking). Their case is very strong, it can be exposed to rain. They have some additional hardware for user identification (smart card reader or RFID, maybe credit card) and cost applying. They can have one or more charging connectors, to charge more then 1 car at the same time. All connectors have mechanical interlock, to avoid cable removal and theft during charge (charging cable is user property). In France and Italy, high power 63A charging columns will have integrated cable and plug (like a fuel refill station), because type-3 connector can manage 32A maximum. Probably it will be the same in all Europe, because user cables able to carry 63A are very heavy.
Public installation *should* connect to smartgrid, when they will exist. I have no much info on this.
All private wall boxes I know are mere charging cables in a fixed installation, with car cable and plug substituted with a panel female connector, so the only difference with a charging cable is that you must use an external car-to-wallbox cable. Connector interlock is not required, because tey are tailored to private places. There are available in 16A and 32A versions, 1-phase and 3-phase. I don't know any of them to be able to communicate with home energy system. You must protect private wall-box with an external overcurrent and differential mode protecting switch, normally delivered together with the wall-box.
I'm designing also a 32A private wall-box that can be connected to external cheap devices (installed in the home) to measure home power draw and photovoltaic power source, to dynamically optimize charge current depending on the actual power availability, to obtain minimum charging time without the risk of overcharging the maximum home's power limit, or prefer auto-charge with photovoltaic produced energy.
Re: bornes mobiles
Si tu comprends le français, utilise google translate pour traduire de l'anglais ou l'italien vers le français.
Re: bornes mobiles
Fais-en de même pour traduire son anglais en français, il fait déjà l'effort de ne pas parler sa langue.Caméléon a écrit:Si tu comprends le français, utilise google translate pour traduire de l'anglais ou l'italien vers le français.
Marsu Pilami- Messages : 751
Re: bornes mobiles
Ce serait peut être effectivement un peu dommage de décourager l'audience internationale du forum, surtout si elle parcourt déjà la moitié du chemin en faisant l'effort de lire le français...
Passant_Mbr- Messages : 5516
Re: bornes mobiles
+ 1000 !
CROLLES- Messages : 1510
Re: bornes mobiles
Pas besoin je le comprends en le lisantMarsu Pilami a écrit:Fais-en de même pour traduire son anglais en français, il fait déjà l'effort de ne pas parler sa langue.Caméléon a écrit:Si tu comprends le français, utilise google translate pour traduire de l'anglais ou l'italien vers le français.
Je parlais pour les autres
Re: bornes mobiles
Je fais davantage confiance à l'Anglais de Davide R qu'au français de Google
Grande braderie chinoise
Morinio a écrit:http://french.alibaba.com/product-gs/car-plug-iec-62196-2-home-charger-463864917.html#
http://french.alibaba.com/product-gs/car-plug-ev-charging-iec-home-charger-with-iccb-530346174.html#
Made in China... J'ai demandé le prix.
Voici la réponse du vendeur :
Thank you for your inquiry! we are willing to establish dirct business relations with you.
The unit price of this product is 295 US dollars
I look forward to your reply!
+transport et taxes on devrait rester sous les 450€
Mais en aura-t'on pour cet argent ?
Morinio- Messages : 4
Re: bornes mobiles
Godewaersvelde a écrit:Marsu Pilami a écrit:Fais-en de même pour traduire son anglais en français, il fait déjà l'effort de ne pas parler sa langue.Caméléon a écrit:Si tu comprends le français, utilise google translate pour traduire de l'anglais ou l'italien vers le français.
+1
Et les explications de Davide R sont très intéressantes.
» Législation concernant bornes fixes ou mobiles
» Sur appareils mobiles
» Le SyDEV remporte les Trophées des territoires électro-mobiles de l'AVERE
» Liste à jour bornes SyDEV et 3 nouvelles bornes rapides à la rentrée
» Bornes 22 kW: Recensement à la "ChargeMap" et suivi de ces bornes
