La BRD, Borne de Recharge de Davide...
+10
mrgrey
nilt
Kermit17
Rxm1t
Davide R
alain68
deltaplouf
14 participants
Re: La BRD, Borne de Recharge de Davide...
bon, la prochaine fois, je préviendrai lorsque j'insère des liens dans mon texte... (les mots "dans un autre sujet" était cliquable et menait directement à l'endroit voulu )jch a écrit:Pour éviter de chercher:
deltaplouf- Messages : 528
désolé, j'avais pas vu le lien !
Davide R a écrit:I never had a Zoe, I quitted my Zoe booking after waiting for 1 year and I bought a 2012 Leaf.mrgrey a écrit:David, you have just leave your zoe for a brand new leaf??
i am thinking about the leaf 2013 , bigger and with the possiblity to charge everywhere with the cro included
wiat and see, but i am looking foward the leaf now
see you for further adventures on your leaf, and thanks for all the things that you ve done to help the zoe community
grey
I think leaf 2013 with 7.3kW charger option is the best car available now. Now it's offered in 3 levels, avoid the 1st cheaper one because it uses power resistors (like my Leaf) for heating that has efficiency 1, while 2nd and 3rd level use heat pump like Zoe that has efficiency 3.
Zoe is nice, smaller and cheaper, but until Renault will put a normal charger (like the one in Kangoo or Fluence) into it I will not suggest anyone to buy a Zoe.
My Leaf charger's efficiency at 10A is about 95%, in the 2013 model it should be better. My standard recharge time at 16A = 3.6kW from 20% to 80% is less than 4h.
I suggest you to read this article about battery's life, it's very interesting: http://www.mynissanleaf.com/wiki/index.php?title=Battery_Capacity_Loss#Real_World_Battery_Capacity_Losses
It's interesting also for Zoe users that like fast recharge.
Bonjour Davide
Ca fait un moment que tu as ta leaf maintenant.
As tu fais le test suivant ?
Faire 1000km puis comparer le nombre de kWh indiqués par la voiture avec le nombre de kWh injectés à la prise pour la recharge. Ca nous donnerait une bonne comparaison en terme d'efficacité de recharge entre la zoe et la leaf non?
nh2o2- Messages : 1863
Bonjour Davide,
initialement, tu prévoyais de sortir l'EV02 à la fin de l'année, tu dois maintenant savoir un peu mieux quelle date de sortie tu peux annoncer ?
Je l'attends avec impatience...
Bonjour Davide,
je déterre un peu le sujet pour savoir si tu as des nouvelles à nous donner sur ta borne EV02 ?
Merci d'avance...
Merci d'avance...
» Prêt d'un Câble de Recharge de Davide (Essonne)?
