La BRD, Borne de Recharge de Davide...
+10
mrgrey
nilt
Kermit17
Rxm1t
Davide R
alain68
deltaplouf
14 participants
Re: La BRD, Borne de Recharge de Davide...
J'ai bien trouvé le prix dans le tableau de recap, mais je ne vois pas de date de disponibilité.
Il y a t'il une date de commercialisation connue ?
nilt- Messages : 14
Petit déterrage de sujet
Salut à tous,
Pour l'instant, je n'ai toujours que le CRD comme moyen de charge à domicile et j'attends avec impatience la Wall Box ELPA pour compléter mon installation et enfin profiter de mes 12 kVA triphasés.
Davide, peux-tu maintenant donner une date estimée de sortie de l'EV02 ? Y a-t-il des problèmes de développement, ou bien c'est la fabrication de CRD qui consomme tout ton temps ?
En espérant pouvoir bientôt la commander...
deltaplouf- Messages : 528
I'm sorry but my company is very small and now I'm fully involved in EVR01 production, that has a good success. I thank all EVR01 users for their appreciations.deltaplouf a écrit:Salut à tous,
EVR02 will be a top level real wall box with all the feature you can think (and others more), I don't want to share all of them now.
Case will change from published pictures (I'm still finding a good one).
A serious problem is that normatives are continuously changing, so the design already got many updates. I hope to have first prototypes before end of year.
merci Davide.
Au fait tu l'a eu ta zoe ?
nh2o2- Messages : 1863
After discovering that the Chamaleon efficiency is between 50% and 80% (I mainly recharge at 8A or 10A to make battery life longer), I quitted my Zoe booking and I bought a Nissan Leaf (2012 model).nh2o2 a écrit:merci Davide.
I'm very happy of it: it's bigger, more powerful, and more efficient than Zoe: charger efficiency is about 90-95%, it has 24kWh of batteries, and max speed is 160km/h (electronically limited). At 110km/h I can drive more than 100km, at 50km/h the range is 175km. Total efficiency is between 6 and 6.5km/kWh, driving half time at 110km/h.
Tiens !
Pour rendre ta borne évolutive Type 3 - Type 2
http://www.avem.fr/news?id=4281&utm_source=feedburner&utm_medium=email&utm_campaign=Feed%3A+actualites_vehicule_electrique_et_hybride+%28Actualit%C3%A9s+du+v%C3%A9hicule+%C3%A9lectrique+et+hybride%29
David, you have just leave your zoe for a brand new leaf??
i am thinking about the leaf 2013 , bigger and with the possiblity to charge everywhere with the cro included
wiat and see, but i am looking foward the leaf now
see you for further adventures on your leaf, and thanks for all the things that you ve done to help the zoe community
grey
grey
mrgrey- Messages : 42
mrgrey a écrit:thanks for all the things that you ve done to help the zoe community
Et que tu vas encore apporter avec l'EVR02.
J'ai hâte de pouvoir charger à plus que 16A avecc mon abonnement de 6kVA tout pourri.
Et plus tard à 11kW quand j'aurai déménagé..
I never had a Zoe, I quitted my Zoe booking after waiting for 1 year and I bought a 2012 Leaf.mrgrey a écrit:David, you have just leave your zoe for a brand new leaf??
grey
I think leaf 2013 with 7.3kW charger option is the best car available now. Now it's offered in 3 levels, avoid the 1st cheaper one because it uses power resistors (like my Leaf) for heating that has efficiency 1, while 2nd and 3rd level use heat pump like Zoe that has efficiency 3.
Zoe is nice, smaller and cheaper, but until Renault will put a normal charger (like the one in Kangoo or Fluence) into it I will not suggest anyone to buy a Zoe.
My Leaf charger's efficiency at 10A is about 95%, in the 2013 model it should be better. My standard recharge time at 16A = 3.6kW from 20% to 80% is less than 4h.
I suggest you to read this article about battery's life, it's very interesting: http://www.mynissanleaf.com/wiki/index.php?title=Battery_Capacity_Loss#Real_World_Battery_Capacity_Losses
It's interesting also for Zoe users that like fast recharge.
thanks david for the advices, i guess it will be a leaf 2013 tekna, i had to examine all the options
Oui, moi j'attends ma LEAF Acenta avec chargeur 6,6kW pour fin août. Je viens de recevoir le EVR01 pour pouvoir charger à 6,6kW.
bragon84- Messages : 32
Je ne suis pas sûr que le rendement soit meilleur à 10A avec le chargeur 6.6 kW, car il sera utilisé au tiers de sa puissance maxi.Davide R a écrit:
Berty- Messages : 144
Le rendement du caméléon se dégrade nettement en dessous de 3,3 kW, soit 7,5% de sa puissance maximale...Berty a écrit:Je ne suis pas sûr que le rendement soit meilleur à 10A avec le chargeur 6.6 kW, car il sera utilisé au tiers de sa puissance maxi.
Si c'est comparable, celui de la LEAF commencera à avoir des problèmes aux alentours de 500W ...
Pour info (et pour revenir au sujet de la discussion), Davide, dans un autre sujet, annonce la BRD (EVR02 de son vrai nom) pour le début 2014, avec plein de fonctions super top méga cool.
Pour éviter de chercher:
I'm designing EVR02, a real smart integrated domestic Wallbox, up to 22kW 3-phase autoregulating (with TIC, french energy counter interface), network controlled with logging capabilities and http server. That design is quite complex, I should have first prototypes at start of 2014. I hope meanwhile the type 2 connector will become standard for all wallboxes in Europe.
bon, la prochaine fois, je préviendrai lorsque j'insère des liens dans mon texte... (les mots "dans un autre sujet" était cliquable et menait directement à l'endroit voulu )jch a écrit:Pour éviter de chercher:
désolé, j'avais pas vu le lien !
Davide R a écrit:I never had a Zoe, I quitted my Zoe booking after waiting for 1 year and I bought a 2012 Leaf.mrgrey a écrit:David, you have just leave your zoe for a brand new leaf??
grey
Bonjour Davide
Ca fait un moment que tu as ta leaf maintenant.
As tu fais le test suivant ?
Faire 1000km puis comparer le nombre de kWh indiqués par la voiture avec le nombre de kWh injectés à la prise pour la recharge. Ca nous donnerait une bonne comparaison en terme d'efficacité de recharge entre la zoe et la leaf non?
Bonjour Davide,
initialement, tu prévoyais de sortir l'EV02 à la fin de l'année, tu dois maintenant savoir un peu mieux quelle date de sortie tu peux annoncer ?
Je l'attends avec impatience...
Bonjour Davide,
je déterre un peu le sujet pour savoir si tu as des nouvelles à nous donner sur ta borne EV02 ?
Merci d'avance...
Merci d'avance...
» Prêt d'un Câble de Recharge de Davide (Essonne)?
